LM-0750W resolution?
COW Forums : Flanders Scientific
Richard Cooper
on Oct 18, 2010 at 8:43:20 pm
Hi Bram, What is the resolution of the Flanders LM-0750W?
Is it a 720p HD field monitor?
Richard Cooper
FrostLine Productions, LLC
Anchorage, Alaska
walter biscardi
Re: LM-0750W resolution?
on Oct 18, 2010 at 9:29:15 pm
Specs are on the FSI website.
It's 800x480 and displays both 720p and 1080 resolutions superbly. Can use as a field monitor or a large Viewfinder for DSLRs and smaller digital cameras.
Has both AC power and a regular Anton Bauer battery plate.
I LOVE this monitor out in the field.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative Media
"Foul Water, Fiery Serpent" Winner, Best Documentary, LA Reel Film Festival...
Blog Twitter Facebook
Bram Desmet
on Oct 18, 2010 at 9:39:26 pm
800x480. Most higher resolution 7" monitors have one or more of these drawbacks as a trade-off for higher resolution:
1. Only 6 bit, not 8 bit, so subject to significant banding.
2. Slow pixel response time.
3. Much higher price.
4. 4:3, so actual resolution for 16:9 sources is not significantly higher than 800x480 wide-screen panel.
The LM-0750W has a very easy to access 1:1 pixel mapping mode that allows you to see any portion of the HD source 1:1. Whatever monitor you get, I would typically suggest adding 1:1 pixel mapping on the 'must have' list, regardless of the unit's resolution. The LM-0750W also has a focus assist feature and a new pixel zoom feature that allows for an adjustable zoom on any portion of an incoming HD signal.
The LM-0750W is very good at what it does provided you have realistic expectations on what the monitor is capable of doing. It is good for establishing focus (especially when using 1:1 mode), it is good for framing, and it is very handy for judgment of exposure with advanced features like our LUM Coloring Exposure Check. Additionally, this monitor features 9 different scopes modes that all work across all inputs, even DVI for DSLR operators and this is something very few monitors can do.
The limiting factors of the LM-0750W are the same as most 7" units at this price or under: color gamut a bit more limited than full Rec 709, resolution not native HD, and requires a hood to be truly suitable for very bright outdoor applications (with a hood this is not much of an issue).
If you are willing to spend twice as much or more there are a lot of decent performing options at the $3,500 to $8,000 price range that can offer higher resolution, wider color gamut, etc. However, at FSI we find that the market for 7" monitors that cost $1,000 to $5,000 more than our 17" monitors ($2,495 list) is relatively limited. For this reason we sourced the best quality panel we could find that would still allow us to sell a 7" monitor for under $2,000 with all of the features found in our larger monitors.
Anyway, I realize that this answer goes well beyond the scope of your original question, but I hope it puts into perspective what you can expect out of our LM-0750W.
Bram Desmet
FSI (Flanders Scientific, Inc.)
© 2018 All Rights Reserved
