sd card emergency-canon 60d
COW Forums : DSLR Video
yotam monk
on Jun 17, 2012 at 12:57:20 am
a very strange sceanrio...
i shoot 6 clips yesterday with my canon 60d
5 of them r perfectly good,but one is making me a lot of problems
i cant copy it to my computer,i have tried many things like convert,trim in the camera,capture the screen while playbacking.. but i keep on failing
by the way english is not native to me...
any new idea on how to get the clip out of the sd card?
the sd card is sandisk extreme 45mbs class 10
the camera is canon 60d
all the best guys
thank you
yotam
Steve Crow
Re: sd card emergency-canon 60d
on Jun 17, 2012 at 2:45:27 am
What happens when you try and copy the mov file over to your computer? Does your computer "see" the file or just the other ones that copied over okay?
If the camera can see and play the file back then you might try using the software that came with the camera that is normally intended to allow you to control the camera from the computer. If this software allows you to play back the clip then you should be able to screen capture it
You said you tried screen capturing but it didn't work, why not? What happened?
Steve Crow
Crow Digital Media
http://www.CrowDigitalMedia.com
yotam monk
on Jun 17, 2012 at 7:55:59 am
what ever apllication im working with it stopps working after transfering 200 mb from the file
i spoke to a friend that says that the problem is that the file hasnt been finelized properly.
screen capture allso aborted at the same point in the clip
and the canon software as well..
Chris Wright
on Jun 18, 2012 at 11:16:03 am
Easeus Data Recovery Wizard can recover flash cards and we use it at work.
