Shotput pro + 7D footage ok ?
COW Forums : DSLR Video
Robin Probyn
on Nov 27, 2011 at 1:20:55 am
Hi there
I have Shotput pro on a Mac book pro.. which I use for downloading nanoflash CF card footage.. to an ext HDD.. works like a dream.. can i do the same with 7D footage CF cards.. shooting 1080/1920 /25p.. what codec are the files..? should I copy over the whole folder or just the video.. whole folder I suspect ?
Dont have the camera so cant check myself..
Liam Hall
Re: Shotput pro + 7D footage ok ?
on Nov 27, 2011 at 12:19:05 pm
Yes, it will work just fine with the 7D.
It's always best to copy the whole volume. It's not much extra data, but will maintain the original file structure should you need it.
The 7D creates QuickTime MOV files using the H264 codec.
Liam Hall
Director/DoP/Editor
http://www.liamhall.net
Robin Probyn
on Nov 27, 2011 at 12:27:24 pm
Thanks for your time .. Roger and copy that advise sir..
Brent Dunn
on Dec 2, 2011 at 4:04:14 pm
Always, always, copy the entire folder. If you use Final Cut, you'll need the extra data to transfer the footage. Otherwise it may not read your video files and you'll have to spend more time transcoding.
Brent Dunn
Owner / Director / Editor
DunnRight Films
DunnRight Video.com
Video Marketing Toolbox.net
Sony EX-1,
Canon 5D Mark II
Canon 7D
Mac Pro Tower, Quad Core,
with Final Cut Studio
HP i7 Quad laptop
Adobe CS-5 Production Suite
Liam Hall
on Dec 2, 2011 at 4:26:47 pm
[Brent Dunn] " If you use Final Cut, you'll need the extra data to transfer the footage. Otherwise it may not read your video files and you'll have to spend more time transcoding."
Just for clarity: that's not strictly true.
Whilst I agree it's best to copy the entire volume, if you have the latest version of the Canon EOS movie plug-in it allows you to import from any folder on your computer. It does not need the original CF card data hierarchy.
http://learn.usa.canon.com/resources/blogs/2011/20110410_eos_movie_plugin_u...
Liam Hall
Director/DoP/Editor
