Exposure Compensation in Movie Mode - Aperture
COW Forums : DSLR Video
Steve Crow
on Oct 22, 2011 at 6:55:07 pm
I notice that with my Canon T2i when I'm in "movie mode" - if I use the exposure compensation function it wants to adjust only the shutter speed in order to lighten or darken the expsoure...I want the camera to leave my shutter speed alone and only adjust the APERTURE value when I'm applying exposure compensation.
Is there a way to do this with the Canon T2i?
If not, is this function available in higher end Canon HD DSLRs like the 7D or the 5DMII?
I can't find a menu setting to let me do this :-(
Liam Hall
Re: Exposure Compensation in Movie Mode - Aperture
on Oct 22, 2011 at 9:26:46 pm
You can use AV mode on the 7D/5D. Though a better option would be to use manual mode and an ND or a fader ND.
Liam Hall
Director/DoP/Editor
http://www.liamhall.net
Steve Crow
on Oct 22, 2011 at 9:29:35 pm
Yes, I do use a fader already but I am curious why the T2i only adjusts the shutter speed while in movie mode when I would much rather have it leave my shutter speed at 1/50 and to only adjust the aperture - but it favors shutter speed and seems to ignore aperture as a way to adjust the exposure...funny
Liam Hall
on Oct 22, 2011 at 9:36:00 pm
I guess if Canon packed all the features into the T2i, they'd be little reason to buy the 7D...
I've not used the T2i, can't you simply turn auto exposure off?
Liam Hall
Director/DoP/Editor
Steve Crow
on Oct 22, 2011 at 9:40:25 pm
Auto exposure is something very different from Exposure Compensation which is there to give you an easy way to adjust the exposure 3-4 stops in both directions (lighter and darker)
Perhaps someone with a 7D can chime in and tell us how it works on higher end models.
Liam Hall
on Oct 22, 2011 at 9:57:55 pm
Lol, I have two 5Ds and two 7Ds...
But I realise I gave you a bum steer as I should have written TV mode to maintain to shutter speed with Exposure compensation. AV mode maintains aperture. I always use manual mode for video but often use AV mode for stills. The exposure compensation is dialled into the camera on the main command dial - you can see how much on the meter - it's all very simple.
Liam Hall
Director/DoP/Editor
Peter Burger
on Oct 22, 2011 at 10:15:12 pm
[Liam Hall] "TV mode to maintain to shutter speed with Exposure compensation"
You can't use AV or TV on the T2i in movie-mode, since the T2i has a special "movie mode" for video. And to my knowledge the only way to auto-control exposure other than shutterspeed is auto-ISO...
But I'm curious if someone has a better idea.
"Tragedy is a close-up; comedy, a long shot." - Buster Keaton
Steve Crow
on Oct 22, 2011 at 10:27:28 pm
Peter, you typed faster than I did but you realized the same thing as I!
Chase Sansone
on Nov 17, 2014 at 9:46:27 pm
To solve your problem press menu, go one over, click the first option "movie exposure", and click manual. Bam! Now in movie mode you can change aperture, shutter speed, and iso. From my knowledge it is basically like manual mode but allows video. I'm super stoked about this function and wish I knew about it sooner. Anyway hope that helped.
Steve Crow
on Oct 22, 2011 at 10:24:24 pm
Oh I see now where the confusion is coming in....it has to do with the different ways the camera controls are layed out on the T2i versus the higher end models. The T2i gives you less control.
On the T2i, the movie mode is one of the dialed in mode options like TV, AV etc. So you can't (on the T2i) be both in movie mode AND use a feature like TV or AV. You can however, like I do, shoot videos in full manual mode giving you full independent control of shutter speed, aperture and ISO. That's how I film 99 percent of the time - and plus I have the Fader ND attached so I can use that which in a funny way is a different kind of exposure compensation :-)
On the higher end models like the 7D, it seems like you can be both in a movie mode and yet still select something like TV or AV which is interesting. In that situation I can see how you might be able to tell the exposure compensation function what to adjust and what to leave alone.
HOWEVER, hmmmm....doing that on the 7D would mean (it sounds like) that I would be giving up full manual control, right?....you see ideally I want the best of both worlds, being able to set aperture, shutter speed and ISO the way I want it AND being able to do quick adjustments with the semi automatic exposure compensation function with the caveat that it doesn't touch my shutter speed (or frankly my ISO either ideally)
Maybe the Fader ND is my best overall option with the 7D as well - it's not automated but close enough. Actually right now I use the exposure compensation METER to tell me how much I am impacting my exposure as I turn the Fader ND - but I don't let the camera actually change my shutter speed which is what it would want to do if I let the exposure compensation mode operate the camera (if that makes any sense to you at all.)
Liam Hall
on Oct 22, 2011 at 10:34:48 pm
[Steve Crow] "On the higher end models like the 7D, it seems like you can be both in a movie mode and yet still select something like TV or AV which is interesting. In that situation I can see how you might be able to tell the exposure compensation function what to adjust and what to leave alone.
HOWEVER, hmmmm....doing that on the 7D would mean (it sounds like) that I would be giving up full manual control, right?....you see ideally I want the best of both worlds, being able to set aperture, shutter speed and ISO the way I want it AND being able to do quick adjustments with the semi automatic exposure compensation function with the caveat that it doesn't touch my shutter speed (or frankly my ISO either ideally)"
Yes, that's what I'm trying (badly) to describe:)
On 7D/5D, if you use TV mode and ISO is not set to auto it will only adjust aperture. You dial in compensation with the main command dial. I can't speak for the T2i as I've never used one.
Liam Hall
Director/DoP/Editor
Peter Burger
on Oct 22, 2011 at 10:35:28 pm
[Steve Crow] ".you see ideally I want the best of both worlds"
I feel your pain, Steve ;) That's one of the reasons I still use my dusty Sony HDV camcorder :) Quick manual controls...
Alex Campbell
on Oct 24, 2011 at 5:48:39 pm
I believe the reason that the default is to change the shutter speed is that when you change the f-stop, there is a mechanical movement in the camera that not only makes a noise, but also makes an abrupt change in the video brightness that is very harsh. On a cinema lens, there is smooth, continuous control over aperture, where as on a photography lens there are finite steps.
Joseph W. Bourke
on Oct 25, 2011 at 12:25:46 am
Another guess at this would be that changing the aperture as opposed to the shutter speed would effect depth of field. It may be setup that way so as to keep DOF consistent in a shot series.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com
