DSLR conversion for PAL
COW Forums : DSLR Video
Andy Snyder
on Oct 13, 2011 at 3:13:50 pm
I have a question about converting footage that I shot on my 5D for use in Australia. I have footage that was shot at 1920x1080 and 24 frames. Unfortunately I did not receive the needed specs for delivery in time for the shoot and therefore need to convert my footage to meet their specs. Basically a case of the cart before the horse I suppose.
The specs for the deliverable are the following:
VIDEO 720 X 576 (unscaled)
AUDIO 24 Bit (Big Endian) 48 KHz
ASPECT RATIO – 16:9 (Full Height Anamorphic)
30 frames
I attempted a few things in MPEG Streamclip but feel like I may have missed something. Any advice on how to do deal with this? I know what needs to be done as far as shooting in PAL going forward but we are trying to use existing footage for the first episode of this series.
Thanks in advance.
Colin McQuillan
Re: DSLR conversion for PAL
on Oct 13, 2011 at 9:18:29 pm
Interesting specs. Pal is 25fps not 30.
Colin McQuillan
Vancouver, B.C.
"Live, love, laugh and be happy."
Colin McQuillan
on Oct 13, 2011 at 9:22:56 pm
In any case I prefer Compressor over mpeg streamclip for frame rate conversions.
What software suite / editing platform do you use?
Colin McQuillan
Vancouver, B.C.
Phil Balsdon
on Oct 16, 2011 at 9:19:39 pm
Check the settings, as Colin said they're not correct PAL with that frame rate.
Also I live and work in Australia and haven't shot an SD job for years, those pixel specs are SD settings.
You should be able to shoot 1280 x 720 or 1920 x 1080 but you must be at 25fps or 50fps and the conversion will be easy to any PAL system.
Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
http://philming.com.au
http://www.steadi-onfilms.com.au/
