Adapter ring troubles/ Nikon F to EOS body
COW Forums : DSLR Video
Ian Clark
on Mar 3, 2010 at 12:56:48 am
Has anybody had trouble detaching the BOWER adapter ring from their Nikon F/ AI lens? I've been struggling for an hour trying to get this adapter ring off of my 50mm f/1.4
It's impossible to press down the release lever with enough pressure and loosen the ring simultaneously.
Feedback on the Novoflex adapter rings- for fitting Nikon F/AI lenses onto Canon EOS cameras? Priced at $270 compared to the $54 Bower brand ring that I am struggling to detach from my lens, the additional cost would be worth it if it makes changing lenses easier.
Click below to check out the NOVOFLEX/BOWER models I'm referring to on BH:
http://www.bhphotovideo.com/c/search?Ntt=Nikon+Lens+to+EOS+body&N=0&Initial...
IAN CLARK | http://www.incproductions.org
Norman Pogson
Re: Adapter ring troubles/ Nikon F to EOS body
on Mar 3, 2010 at 1:26:25 pm
The adapter ring I have you don't push down on the release you pull it sideways away from the lens.
My Canon 7D Blog
Ian Clark
on Mar 3, 2010 at 4:42:28 pm
Hey Norman,
What kind of lenses are you using? You might have a completely different mount than the ones I'm referring to. Mine turns/locks onto the back of the lens- Nikon AI- then you place the lens onto the EOS body.
Norman Pogson
on Mar 3, 2010 at 6:35:50 pm
Hi Ian,
I'm using old Nikkor AI lenses I have four different ones on my 7D, I put the adapter on the lens first which locks into place then I put it on the body.
Mine is the cheap ebay adapter from China, here is a link to a similar one: http://tinyurl.com/yklpzau
It has a small lever which you pull away from the lens to unlock the adapter and then twist off.
My Canon 7D Blog
James Leaburn
on Mar 3, 2010 at 8:38:43 pm
If you are looking for a replacement, I got one of these on recommendation and it goes on and off no bother.
http://www.fotodiox.com/catalog/product_info.php?products_id=123
If in doubt scream and shout.
Ian Clark
on Mar 3, 2010 at 9:01:59 pm
Thanks for the info, James. Does yours work on both AI and AI'd lenses? Maybe I just bought a lens that received poor craftsmanship in its AI conversion.
Take care-
