H264 compression shifts gamma only in original DSLR footage
COW Forums : DSLR Video
Lindsey Grayzel
on Oct 4, 2011 at 8:16:45 pm
Hello,
I have been reading all the various posts about H264 gamma shifts all morning. Here's my workflow:
Shoot on 7D DSLR and Sony Ex-3
Convert the DSLR footage to Apple Pro Res
Edit in Final Cut 6.06 in an Apple Pro Res timeline. (Ex-3 footage gets rendered in timeline.)
Everything looks beautiful.
Export full res. quicktime file with current settings.
Everything still looks beautiful.
Compress to H264
Now the shots that were originally from the EX-3 still look beautiful, but the shots from the DSLR are washed out, low saturated color.
I can get the DSLR shots to look beautiful again by adding a gamma correction filter of 1.2, but that makes the shots from the EX-3 way too dark.
Incidentally, I'm using a Matrox box for the H264 compression, but I have tested without it and get the same results, so I don't think that's figuring into the mix.
I'd appreciate any and all suggestions!
Thank you,
Lindsey
Owen Wexler
Re: H264 compression shifts gamma only in original DSLR footage
on Oct 17, 2011 at 6:35:03 pm
Quicktime H.264 is notorious for its gamma issues. If you have Adobe Media Encoder, try using that to convert to an H.264 MP4... that might help.
Cinematographer - Editor - Motion Graphics Artist - Colorist
http://www.owenbwexler.com
