720 50p dslr and 25p
COW Forums : DSLR Video
Tielman Dewaele
on Sep 18, 2011 at 11:02:14 am
Hey im new the dslr editing so i would like to have some advice before we start to edit in a week or so.
I am using pp 5.0
I shot ALL my clips for a music video in 720p 50fps, because i could then use slomo's when ever i wanted.
Most of the footage will be used for normal speed.
I just used the dslr preset from pp 720p 50ps. So ill be editing the 50p's (no slomo). When i want to use slomo's should i then just change it to 25p in the interpret settings? will that work? Is that correct? I dont need audio to synq.
Output eventually should be 25p.
MacPro Intel Quad Core 17G Ram
MacBookPro Intel Duo Core 2G Ram
Cs5 Production Premium
Cinema4D 11.5
Final Cut Studio 2
Michelle Mizner
Re: 720 50p dslr and 25p
on Sep 20, 2011 at 2:56:08 pm
You should take the clip, duplicate it, and bring that into Cinema Tools and change the frame rate. Tutorial here:
Hope that helps!
Alex Campbell
on Sep 28, 2011 at 1:11:25 am
In PP, you do not even have to do that much. Simply create a 25P timeline and adjust your clip using the "speed/duration" setting when you right click on it in the timeline. Set the speed to 50% and you are done.
I am a recent PP convertee and this is a lot better than conforming the clip.
© 2018 All Rights Reserved
