Would Canon 18-135mm f3.5-5.6 IS be a good upgrade from 17-85 f4-5.6 IS USM
COW Forums : DSLR Video
Ben Edwards
on Jul 14, 2011 at 11:54:49 am
I am quite happy with my Canon EF-S 17-85 IS USM lens but it would be good if had a slightly longer zoom. I recently came across the Canon 18-135mm f3.5-5.6 IS and thought it may be a good upgrade. Has anyone used both these lenses, what are the pros and cons?
Regards,
Ben
Ben Edwards - Freelance Filmmaker
http://www.funkytwig.com
Phil Balsdon
Re: Would Canon 18-135mm f3.5-5.6 IS be a good upgrade from 17-85 f4-5.6 IS USM
on Jul 16, 2011 at 4:01:52 am
You could try a 70-200 then you'll have all the way from 17 to 200.
Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
http://philming.com.au
http://www.steadi-onfilms.com.au/
Ben Edwards
on Jul 16, 2011 at 9:04:23 am
Thanks for replying. I already have a long zoom. I am interested in the 18-135 because it would mean I hardly ever had to change lens. I keep my 17-85 on the camera almost all of the time and when I change it is only to get a little extra zoom. With a 18-155 lens would probably drop to under 1%. This is a big example for the type of run and gun work I tend to do.
