Dust in the viewfinder
COW Forums : DSLR Video
Casey Petersen
on Jun 16, 2011 at 3:00:14 pm
What is the best way to remove dust from the inside of the viewfinder...compressed air?
I don't want to hurt anything inside before I do anything.
Casey
Matt Doe
Re: Dust in the viewfinder
on Jun 16, 2011 at 4:48:16 pm
If you are referring to compressed air as the stuff in the can from the electronics store, NO. Air in a can has chemicals that can do a lot of harm to your camera.
If you have an actual air compressor, that should work just fine.
André Engelhardt
on Jun 16, 2011 at 7:22:24 pm
Hi Casey,
the number one tool that should be in every photographers toolkit is this item:
http://www.bhphotovideo.com/c/product/259157-REG/Giottos_AA1900_Rocket_Air_...
It's safe, easy to use and lasts forever.
Good luck!
André
Audio Engineer, Sound Designer
Video- and Photographer
http://www.andreengelhardt.net
