Nikkor glass on cropped 7D sensor
COW Forums : DSLR Video
John Young
on May 22, 2011 at 3:38:23 pm
I am not sure why I have been unable to figure this out, but I have searched around a lot and haven't got what I am looking for. So I turn to you good folks on the COW.
I have a Canon 7D, so it has the 1.6x cropped sensor. I also recently got a great Nikon Nikkor 50mm Ai lens off ebay. I assumed the lens would be closer to 80mm because of the crop factor on the 7D's sensor. But I don't think this is the case. I compared it to my Canon EF-S (so the lens is made for crop sensor) 17-55mm. And the Nikon 50mm looks pretty close to the Canon at 55mm. Pictures below.
This is the Canon lens at 55mm.
a href='http://i1.creativecow.net/u/130999/canon55mm.jpg'>
This is the Nikon 50mm
href='http://i1.creativecow.net/u/130999/nikon50mm.jpg'>
It looks like the Nikon is true 50mm. Right? What am I not understanding about this?
All thanks in advance.
http://www.johnathanyoung.com
Errol Lazare
Re: Nikkor glass on cropped 7D sensor
on May 22, 2011 at 4:45:15 pm
The 50mm Nikor looks very close the the 55 canon lens but looks to be a bit wider (since it is 5mm smaller). But because you are using a crop sensor that 50 would really be around an 80/85. If you put that on a 5d it would be much wider. It shouldn't matter what brand of lens you are using because a 50mm on a Nikor is a 50mm in general.
Try throwing a 35mm lens onto your crop sensor camera to give you an idea what your 50mm would look like on a fullframe camera
Errol X. Lazare
EXL Films
http://www.exlfilms.com
Noah Kadner
on May 22, 2011 at 7:00:34 pm
Yeah the EF-S 50mm still gets cropped as a regular lens would. Can't change the physics...
Noah
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and Canon 7D.
John Young
on May 23, 2011 at 5:14:52 pm
[Errol Lazare] "The 50mm Nikor looks very close the the 55 canon lens but looks to be a bit wider (since it is 5mm smaller). But because you are using a crop sensor that 50 would really be around an 80/85."
That is why I am confused. It looks likes it is only 5mm wider, when I would think it would tighter (like the 80/85mm you mentioned).
So then I can come to 2 conclusions, neither which make sense to me.
1) My Canon EF-S 17-55 is not true 17-55. But the B & H info states clearly it is not for full frame sensors, it is made for APS-C sensors
2) For some reason the Nikon 50mm is closer to actual 50mm than the 80mm it should be on the cropped sensor, but I have not idea why.
Thanks guys.
Brent Dunn
on May 23, 2011 at 5:50:44 pm
The bigger lens are wider glass, but the cropped sensor is similar to being zoomed in a bit.
You can have a piece of glass 3 inches wide and look through a 2 inch hole, you only see 2 inches of the glass. You can then get a 4 inch piece of glass and look through the 2 inch hole, it looks the same even though the glass is bigger. This ends our lesson for today class : )
Brent Dunn
Owner / Director / Editor
DunnRight Films
DunnRight Video.com
Video Marketing Toolbox.net
Sony EX-1,
Canon 5D Mark II
Canon 7D
Mac Pro Tower, Quad Core,
with Final Cut Studio
HP i7 Quad laptop
Adobe CS-5 Production Suite
Colin McQuillan
on May 23, 2011 at 7:31:16 pm
Basically what 'Professor Dunn' is saying is that your 17-55mm lens, that is made specifically for an APS-C sensor, is going to give you the same framing on your APS-C body as 17-55mm lens that is made for a full sensor camera.
a 50mm lens is a 50mm lens. Some are less wide inside and can't be used on a full-frame camera (well,, you can for interesting boarder effect..)
The difference is that the APS-C lens uses smaller diameter glass.
The mentality behind this is that the APS-C lenses cost less to build, and thus cost less to the consumer...
In the end I always go for the full frame lens' to future proof new bodies down the road.
Colin McQuillan
Vancouver, B.C.
"Live, love, laugh and be happy."
