Confused on HDMI monitoring in 60D
COW Forums : DSLR Video
clyde villegas
on Apr 29, 2011 at 1:11:05 am
I have read in one forum that when monitoring from the HDMI out, the resolution drops to 480p when using a Canon 60D. In another forum, someone says it's still at full HD. Which one is true?
ut in omnibus glorificetur Deus
Ryan Orr
Re: Confused on HDMI monitoring in 60D
on May 9, 2011 at 6:55:24 pm
The 60D sends a 480p signal through the HDMI during Live View Mode, and is complimented with a red circle in the corner to indicate that it is recording. It still is recording to the SD card in whatever resolution/fps you have it set to, but the hdmi signal will always be dumbed down.
Anyone who says otherwise is wrong...unless there is a new Magic Lantern firmware hack that I don't know about, but I'm usually one of the first to know these things.
