HD H2.64 to SD conversion
COW Forums : DSLR Video
Nick 2746
on Mar 14, 2011 at 10:43:56 am
I have not been able to convert HD to SD satisfactorily to edit in FCP. I use MPG Streamclip with the following settings:
Compression: Apple DV PAL
Quality: 100%
Frame Size : 720x576 (DV PAL)
Interlaced scaling: On
The problem is slight strobing when the subject moves in the frame, which is very disconcerting. If I turn the Interlaced scaling off then I can't view the movie on an SD monitor.
I would greatly appreciate help as it is driving me mad.
I have not problems when I am working in HD and the results are great.
Jason Jenkins
Re: HD H2.64 to SD conversion
on Mar 14, 2011 at 8:04:37 pm
Why don't you edit in HD, then downconvert for delivery if necessary.
Jason Jenkins
Flowmotion Media
Video production... with style!
Nick 2746
on Mar 14, 2011 at 8:32:33 pm
Yes, I have done it that way in the past but then Compressor takes a long time to prepare the files for DVD SP, especially for a 45 min programme.
Where as if I convert it to DV PAL frmat first then a 45 min long programme takes only 15-20 min to prepare files for the DVD SP. So, that seemd sensible.
Peter Burger
on Mar 15, 2011 at 9:16:24 am
[Nick 2746] "If I turn the Interlaced scaling off then I can't view the movie on an SD monitor."
I'm not sure, if I understand correctly. If you turn interlaced scaling to off, results in a file that can't be played? Or is the quality not good?
You could try to resize and convert to a different codec, like Photo-Jpeg at 90% (or higher), which produces quite good results.
