Tamron Lens on T2i?
COW Forums : DSLR Video
Zevie Tannenbaum
Tamron Lens on T2i?
on Mar 11, 2011 at 10:41:57 am
I ordered a T2i and I have two Tamron lenses. First is a Tamron SP 28-105mm 1:2.8 and the second one is a Tamron 28-300mm lens 1:3.5-6.3 (Macro). Are they going to work out, or do I need an adapter?
Phil Balsdon
Re: Tamron Lens on T2i?
on Mar 11, 2011 at 9:30:06 pm
Are the Tamron lenses EOS mounts? If so yes they will fit.
If thet are another brand, Nikon or Pentax for instance you can most likely make them work with a suitable adaptor.
The 28-105 is a good lens for HDSLR video work. The 28-300 will work but it doesn't have a constant iris function, which means as you zoom the exposure will change.
Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
© 2018 All Rights Reserved
