Flying a 7D
COW Forums : DSLR Video
Frank Giardina
Flying a 7D
on Mar 4, 2011 at 2:21:19 pm
Good Morning....
We'll be flying a 7D or 60D soon. We've been shooting 24p, but I'm wondering if 30 might be better when flying a DSLR?
Best Friday Morning Regards!!!
Frank Giardina
17 Video Production
Shane Ross
Re: Flying a 7D
on Mar 4, 2011 at 3:07:57 pm
What would flying have to do with the frame rate you shoot? Many many aerial shots are done 23.98. Including film (well, that's actual 24fps).
You shoot the frame rate that you are working with...don't change it just because you are shooting some other thing. Keep a consistent frame rate throughout your project. Mixing frame rates in projects is highly problematic.
Shane
Frank Giardina
Re: Flying a 7D
on Mar 4, 2011 at 4:08:02 pm
Hi Shane...
Yes, maintain a constant frame rate for sure. Movement and DSLR footage sometimes don't mix well... I was thinking going to 29.97 might help a little?
Frank Giardina
17 Video Production
Jonathan Ziegler
Re: Flying a 7D
on Mar 4, 2011 at 6:21:25 pm
Basically you want to avoid whip pans, jarring camera movements, and I don't personally care for handheld with dslrs. Now, if you follow the old advice from the days of film, you can move the camera, but keep motions fluid and natural and avoid vertical lines and objects, small, tight patterns, etc. Visit http://www.nofilmschool.com in the dslr section for tons of great info. Using a longer shutter will work to help smooth out rough edges, but good camera work in general will help you out a lot.
Jonathan Ziegler
http://www.electrictiger.com/
520-360-8293
Dave LaRonde
Re: Flying a 7D
on Mar 8, 2011 at 5:14:09 pm
You don't mention if the camera will be stabilized. For aerial footage, it's essential. The engine vibrations will ruin otherwise fine footage.
Don't skimp on the stabilization, or you'll just be throwing your money away on aircraft rental.
And I, for one, would shoot at 59.94/60; that particular frame rate lends itself well to frame rate conversion and minimizes motion blur, which can happen when shooting in turbulence.
Dave LaRonde
Sr. Promotion Producer
Jonathan Ziegler
Re: Flying a 7D
on Mar 8, 2011 at 5:22:40 pm
Do you mean you are literally flying with the camera (ie: taking on a plane, blimp, balloon, etc.) or did you simply mean you were using a DSLR (flying as a metaphor)?
Jonathan Ziegler
520-360-8293
