Magic Lantern Questions
COW Forums : DSLR Video
Ben Edwards
on Feb 24, 2011 at 5:20:31 pm
Hi All,
Thanks to Jonathan Ziegler, I have now got ML working on my 550D.
When I put the SD card with firmware in it and power up it starts. Originally I though I kept a card to boot the Camera and then could change card but when I remove card camera powers down. Do I need the firmware on all cards?
Also are there any guides/documentation to using ML. I have looked on the ML Wiki but cant find anything.
Regards,
Ben
Steve Crow
Re: Magic Lantern Questions
on Feb 24, 2011 at 6:46:03 pm
Yes, I'd like to know the answer to this too :-)
Rafael Amador
on Feb 25, 2011 at 2:19:03 am
I don't work with DSLRs, but as long as I know the software needs to be loaded every time you power the camera up. So, yes; you need the ML firmware on every card.
rafael
http://www.nagavideo.com
Peter Burger
on Feb 27, 2011 at 10:56:31 pm
Can confirm Rafaels answer. ML has to be on every card. If you delete the ML files or format the card, ML is gone.
Don't know which version/build you have, but in the ML version that I use there's a PDF included, that gives (more or less) detailed information about all features.
Thomas Pohl
on Jun 7, 2011 at 7:47:41 pm
Which ML version are you using? I tried the 0.2.0 Version on the 550d from december and the last from 31th of may. Both are too buggy to use it seriously.
Cheers
Thomas.
http://www.footage-online.de - RED footage and more available in HD, SD and RED RAW R3D
Suley Suleman
on Jul 2, 2011 at 4:17:36 pm
What version ML do you use? Would you be able to provide a link to where you dl'd from with the PDF or upload the manual. Also what version would you recomend for a 550d?
