Converting 60p footage to look like it was shot 24p natively.
COW Forums : DSLR Video
Austin Steele
on Jan 27, 2011 at 8:25:27 pm
I shot some stuff in 60p on the 7D. I wasn't sure if I wanted the final footage to be slow-mo or to look like native 24p. Is there a way that I can my footage to look close to native 24p footage?
Any help is appreciated.
Richard Cooper
Re: Converting 60p footage to look like it was shot 24p natively.
on Jan 27, 2011 at 11:13:26 pm
Try going through the normal conform process in Cinema Tools and get it to standard 23.98 frame rate and then speed it up to 300% in your edit suite time line.... This will allow the footage to played back at 23.98 fps by dropping frames and not playing it back a 60 fps like the original shots.
I think you will be surprised.
Richard Cooper
FrostLine Productions, LLC
Anchorage, Alaska
http://www.frostlineproductions.com
Austin Steele
on Jan 28, 2011 at 1:11:33 am
That's what I did and it really just looks like 60p. Is there any better ways to do this or is this really my only option?
Richard Cooper
on Jan 31, 2011 at 6:37:09 pm
Run me through your work flow, cause that is NOT the result we get here.
Richard Cooper
Anchorage, Alaska
Rafael Amador
on Jan 28, 2011 at 1:39:40 am
Fallow Richard advice, or you may try as well MPGStreamclip.
rafael
http://www.nagavideo.com
ibrahim mohammed
on Mar 31, 2011 at 10:07:05 pm
Hi
Try this it's free
http://library.creativecow.net/articles/kramer_andrew/fps.php
let me know the results
Good luck
