Elgato Turbo H.264 slows down to 1fps!?!
COW Forums : DSLR Video
Aaron Steven
on Jan 24, 2011 at 8:49:07 pm
Hi all.
So I purchased the Elgato Turbo.264 HD encoder a while back and I have been using it frequently. Despite the crushing of some blacks, its a great program. But recently after updating to version 1.1.3 the program doesn't seem to work...at all. I've tried a variety of compression settings and my most standard is nothing extra strenuous. Im crushing footage from a Canon 5DMKII to 1280x720 with a data rate of 5000. If you are familiar with vimeo's upload guidelines for HD, those are the exact settings I am using.
When I start the compression within seconds El Gato stretches out to 001fps and the time goes sky high. I don't understand, these are the exact same compressions I have been doing for over a month.
Im on a Mac G5 with Dual 2.8Ghz Quad-Core Intel Xeon Processors and 6 GB of 800MhZ DDR2 ram, so Its not my system..
Anybody encounter this before? Thanks in advance for any help.
-Aaron
Rafael Amador
Re: Elgato Turbo H.264 slows down to 1fps!?!
on Jan 24, 2011 at 9:58:43 pm
[Aaron Steven] "When I start the compression within seconds El Gato stretches out to 001fps and the time goes sky high. I don't understand, these are the exact same compressions I have been doing for over a mon"
Did you had a look to the Activity Monitor?
rafael
http://www.nagavideo.com
Zane Barker
on Jan 25, 2011 at 7:56:42 am
[Aaron Steven] "Im on a Mac G5 with Dual 2.8Ghz Quad-Core Intel Xeon Processors"
Well which is it a G5 or an intel, because it cant be both.
The Elgato Turbo.264 HD is Intel only.
http://www.elgato.com/elgato/na/mainmenu/products/Turbo264HD/product3.en.ht...
As for issues with the Elgato Turbo.264 HD, this clearly is NOT a Elgato Turbo.264 HD forum. I would recommend going to Elgato's Forums.
**Hindsight is always 1080p**
