Shooting 720p HD producing Bad Results?
COW Forums : DSLR Video
Ravi Kanda
on Jan 16, 2011 at 12:54:58 am
Hi Guys
I've been trying to work this out for while. Hopefully you could help.
I've shot 720p HD footage a few times now, connected my Nikon D5000 to my mac and transferred the AVIs across. However, the videos never seem good quality! They appear to have been shot on a much lower pixel rate.
Is the problem in the transferring? I have Final Cut Pro if that helps.
Thanks in advance.
Ravi Kanda
Re: Shooting 720p HD producing Bad Results?
on Jan 16, 2011 at 1:09:29 pm
I used a tripod and there was enough lighting for the video.
Any help would be great guys
Peter Burger
on Jan 16, 2011 at 1:43:18 pm
How did you transfer the files? If there wasn't any transcoding involved in transferring, the clips must be the same quality.
Ravi Kanda
on Jan 16, 2011 at 1:49:52 pm
I'm transferring files straight from my DSLR without any transcoding.
It's such a strange issue. I'm sure I'm doing something wrong.
Peter Burger
on Jan 16, 2011 at 1:56:25 pm
So the quality loss (if there is any loss at all), can't be produced by transferring.
Do you watch your clips in your NLE or in a player like Quicktime or VLC?
If watched in your NLE, it can be a NLE issue (wrong settings).
Ravi Kanda
on Jan 16, 2011 at 8:42:34 pm
This is a sample video I took to show you what I'm saying:
Look how grainy the video is at 720p.
Peter Burger
on Jan 16, 2011 at 11:26:32 pm
What were you're settings?
Ravi Kanda
on Jan 17, 2011 at 9:54:17 am
On my camera, they were 1280x720.
Would I need to change the settings on my player too?
Peter Burger
on Jan 17, 2011 at 1:13:47 pm
No, I mean, what were your recording settings, like aperture, ISO, shutterspeed etc...
Ravi Kanda
on Jan 17, 2011 at 1:26:10 pm
Ah sorry.
Even if I change my ISO to any setting, I still get the same results. Should video be as grainy as mine in HD?
My shutter speed was 1/50 and aperture at 5.4
I am using the standard 18-55 kit lens. I have a 50mm too.
Is there anything I could film or send you any settings that might help?
Ravi Kanda
on Jan 17, 2011 at 1:30:46 pm
Is there any way I can test if my ISO settings are actually working?
I mean, how can I find meta data like ISO, Aperture etc in FCP?
Or if you know of any software that does this?
Peter Burger
on Jan 17, 2011 at 2:37:56 pm
I have a Canon cam myself, so I can just guess...
The Canon cameras save a thumbnail file for each clip, that contains all of the meta-data (EXIF) of the clip and can be read with an exif-viewer. Don't know, if the Nikon does something similar. Watched your Youtube-clip and it is indeed grainy. I'm not sure if it's the Youtube compression, but I would suggest there is something wrong with your ISO settings. Are you sure you were shooting manual with low ISO?
Ravi Kanda
on Jan 17, 2011 at 2:53:47 pm
Yeh I always shoot manual. My ISO setting was 200.
The video appears like this even before I upload it to youtube.
I don't get this.
Mark Petereit
on Jan 17, 2011 at 10:57:15 pm
Wow, you're getting that shallow DOF at 5.4? The footage you posted looks more like it was shot wide open in low light, which would account for the noise.
Ravi Kanda
on Jan 17, 2011 at 11:13:13 pm
Yeh thats f/5.4.
The lighting was ok. It wasn't really low.
Is this common to get this much grain?
Peter Burger
on Jan 18, 2011 at 9:17:36 am
Is there a way to change compression settings with your Nikon? Everything that is in focus seems to be ok, but all the parts that are out of focus, have a lot of chroma noise and are very blocky... So to me it looks like heavy compression artifacts...
Did you switch all image enhancing methods to off (supposing there are any - the canons have "auto lightnig optimizer" and "highlight tone priority", which sometimes create weird artifacts)?
Ravi Kanda
on Jan 18, 2011 at 9:31:37 am
The only thing I have on auto is White Balance.
Mark Petereit
on Jan 18, 2011 at 12:55:06 pm
"The only thing I have on auto is White Balance."
Turn that off. Get a white card (and perhaps a set of warm cards), set your white balance before you shoot then leave it alone. I doubt that that's what's causing your issues, but it's just generally good practice.
