60D audio problem, bug?
COW Forums : DSLR Video
bruno perosa
on Nov 21, 2010 at 6:34:45 am
I have the 60D from 3 weeks now, it's great both in stills and video and I was using the external mike input both with a wireless and with a mixer OK, (you have to put the manual level to 0 and the to the very 1st step from left to have the right level). BUT today a problem developed using an external radio lapel radio receiver. The external input ceased to work, even when you plug a simple mini-jack it should interrupt the internal mike. NO LONGER. I cannot get an external input anymore. It always work with the internal mike... Anybody has experienced this kind of problem? Bug?? Weak socket?
EX3, Nikon Adaptimax with various lenses, Canon 60D + 24-105 L IS USM & EF 28mm 1.8 USM & Nikon adapter; Acuter Merlin mount, MBP17"2.93GHz, FCS2, Media100, BtcSP, DVcam
Michael Sacci
Re: 60D audio problem, bug?
on Nov 23, 2010 at 7:30:04 pm
That is not really a BUG, that sounds like the jack went bad. All you can do is to test out the equipment on another piece of equipment, if it works you have a bad mic jack.
