HDSLR converion without FCP
COW Forums : DSLR Video
Rasmus Jürs
on Nov 16, 2010 at 10:49:42 am
Im "new-ish" to this editing thing still and there doesn't seem to be any guides out there explaining what the best format for CC in premiere/AE is when it comes to Canon HDSLR footage (In my case 7D).
They all show you how to do it with FCP. and the ones that show you how to do it in Premiere all use Compressor and ProRes.
In my head that is totally useless info. why would i use (and buy!) FCP just to use the compressor and then edit in Premiere!?
Then i read somwehere that i dont need compressor, just the ProRes components (ONLY BUNDLED WITH FCP!). Is it really possible that i cant get the most out of my 7D footage without this apple product?
I am using a Macbook pro to edit but the integration between the programs in CS5 Master Collection is far superior to what FCP has to offer. Besides, what does non mac users do? are they doomed to always work with the HDSLR native files just because they cant run FCP?
What im looking for is info on what settings work the best when it converting the footage in something like "MPEG Streamclip" or perhaps some other software. (Doesnt have to be free.)
The Native fileformat runs soothly in Premiere CS5 but im told that it doesnt hold up very well when you try to Color Correct it.
Rasmus Jürs
Steve Crow
Re: HDSLR converion without FCP
on Nov 16, 2010 at 5:05:48 pm
Here's a link to a video I did explaining how to use MPEG Streamclip to convert HD DSLR footage.
http://crowdigitalmedia.com/hd-dslr-workflow-%E2%80%93-part-2-%E2%80%93-tra...
Now I use FCP and a Mac so I convert my footage to ProRes LT - you will want to instead convert your footage to a PC friendly format.
Cineform is the one I hear the most about but you will probably have to buy this codec before MPEG-Streamclip can convert your files to that format. If you already have Cineform installed on your system then you should be ready to go.
Here's the Cineform encoding application: http://www.cineform.com/neoscene/
You could also try exporting AVI or MOV files out of MPEG Streamclip since I assume Premiere can work with these formats. By the way, I am noticing a growing trend of people running Premiere on a Mac for HD DSLR editing - in other words moving away from FCP.
All the best to you!
Lance Bachelder
on Nov 16, 2010 at 5:33:45 pm
If you're happy with the real-time performance of cutting native Canon footage in CS5 then there's no reason to convert first. You can do color timing on the original footage in Premiere or open your finished cut in After Effects and use Color Finesse. Or cut your show first and render it to a better codec like Avid DNxHD (free on the Avid site) which is similar to ProRES and color time that. Lots of options and no you don't need FCP.
That said, all this buzz about switching from FCP to CS5 is just crazy. Yeah CS5 is great and has nice integration between apps, but as far as NLE's go and true professional editing tools, Premiere is seriously lacking in features as compared to NLE's like FCP or Avid. This doesn't mean that you can't do pro work with Premiere and if that's all you've ever you used you may never miss the tools I'm talking about, but there is a significant lack of editing features, some even basic, in Premiere Pro.
Lance Bachelder
Southern California
Rasmus Jürs
on Nov 16, 2010 at 6:14:24 pm
Thanks for the answer.
My day to day work is primarily focused on printed media and web. But sometimes we get requests for small video productions. (Primarily web based) so i for the time being Premiere and After Effects more than encompass the range of tools i need.
But since i'm still kinda new to the HDSLR thing, i haven't really nailed my workflow yet.
That is why im looking around for the possibility that converting to a format and codec that might improve the editing and CC speed and quality would be very welcome.
So when i read that FCP users should convert to ProRes to get better editing and CC capabilities i started wondering if there was a similar process for Premiere users.
And like Steve suggested, Cineform might be something to look into.
Ben Holmes
on Nov 17, 2010 at 5:06:04 pm
If you want a fast, simple and cheap solution for transcoding DSLR footage to ProRes for use in FCP, I would recommend Magic Bullet's Grinder. I think it's $50, and uses all 8 cores on a Mac Pro to transcode 8 files at once. Drag and drop batch simple.
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producer
http://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
Rasmus Jürs
on Nov 16, 2010 at 5:57:28 pm
think i might look into the cineform solution. at least try the free trial. Just to see if it gives a tangible difference.
thanks
