General rule for "image settings"
COW Forums : DSLR Video
Tony Connoly
on Oct 21, 2010 at 12:01:26 pm
All DSLRS have have image settings that I've generally ignored because in still photography they don't affect the RAW image. These include:
White Balance
Picture Mode (Normal, Potrait, Vivid, Muted etc.)
Contrast
Saturation
Noise filtration/noise reduction
Sharpening
I've already learned that sharpening should be turned down as much as possible. How about the others...is there a rule of thumb that you use as a starting point that allows for easy post processing?
Steve Crow
Re: General rule for "image settings"
on Oct 21, 2010 at 3:05:48 pm
You should Google HD DSLR gurus like Vincent Laforet and Shane Hurlbut to get specific setting ideas - Vincent has published his camera "formula" for more cinematic video several times - here's a link to a video to get you started but there are many more resources to be found via Google
Oh and let's not forget the master Philip Bloom - he has a DVD out showing his specific settings. Stu Maschwitz - another great resource for you - has this:
http://prolost.com/flat/
Tony Connoly
on Oct 22, 2010 at 10:53:14 am
Thank you. That was helfpful, but the video didn't go into a lot detail. Any other info would appreciated it.
Steve Crow
on Oct 22, 2010 at 3:22:09 pm
bruno perosa
on Oct 28, 2010 at 3:24:30 pm
is it the same for the 60D as well?
EX3, Nikon Adaptimax with various lenses, Acuter Merlin mount, MBP17"2.93GHz, FCS2, Media100, BtcSP, DVcam
