Looking for a great field monitor.
COW Forums : DSLR Video
Richard Cooper
on Oct 15, 2010 at 11:33:38 pm
Hi All,
I am looking for a great monitor for use with both my EX1 and my 7D out in the field.
I need both inputs - HD/SDI (EX1) and HDMI (7D), a true HD monitor (720)
I have looked at the Small HD http://www.smallhd.com/Products/DP6.html and it has both inputs available but it is only a 5.6" monitor and I would like to have at least a 7" inch.
The "no brainer" field monitor is the Flanders LM-0750W http://www.shopfsi.com/FSI_7_inch_hd_broadcast_monitor_p/lm-0750w.htm which has everything EXCEPT HDMI inputs.
Has anyone here seen or used the Manhattan monitors?
http://www.manhattanlcd.com/product_p/7011.htm
It seems to have everything I need, HD/SDI and HDMI inputs, it is 8.9" and has 1280x768 resolution, plenty of power options... but is it a great monitor?
Am I missing any great options out there?
Would love to hear your thoughts. Thanks for your input.
Richard Cooper
FrostLine Productions, LLC
Anchorage, Alaska
http://www.frostlineproductions.com
Errol Lazare
Re: Looking for a great field monitor.
on Oct 16, 2010 at 1:01:30 am
Marshal makes a good field monitor with Anton Bauer battery mount.
Errol
Errol X. Lazare
EXL Films
http://www.exlfilms.com
Richard Cooper
on Oct 16, 2010 at 1:20:50 am
Hi Errol, Thanks for posting. I have never been impressed with Marshall Monitors. The main reason being, that I cannot seem to find a 7" Marshall that has HD resolution... they are all 800x480. But I may have found my answer... see my next post!
Richard Cooper
Anchorage, Alaska
Richard Cooper
on Oct 16, 2010 at 1:28:02 am
SOLUTION!
While looking again at the Flanders site, I found that they sell a Mini-HDMI to DVI cable to connect the 7D directly to the LM-0750W through the DVI Port. Brilliant! (no power supplies for an HDMI to HD/SDI converter!)I had not considered a DVI conversion but this seems to be the answer. And I still get HD/SDI for my other cams. Very nice. Anyone see a problem with this?
Thanks FSI!
Richard Cooper
Anchorage, Alaska
Bob Pierce
on Oct 16, 2010 at 1:28:13 pm
Richard,
If you end up getting the FSI I'd love to hear what you think of it. I've had my eye on it for a while buy can't find any reviews.
Bob
http://www.lightstreamassociates.com
Mac Pro 2.66 - 8GB memory -
Mac Book Pro 2.33 Duo -
FC Studio 2 - Kona Lhe
Adobe Production Suite CS4 -
Sony Multiformat 14" - Panasonic 42" Plasma -
Ikegami HLDV7 - PVW EX-1
Phil Yunker
on Oct 18, 2010 at 8:28:48 pm
Richard, did you end up going with the Flanders and the DVI -HDMI cable? would like to hear what you think. Also, Marshall makes a monitor (the V-LCD651stx-HDMI-PM) that is 1024x768 but it's only 6.5"
isn't the Flanders 800x480?
Anyway, I would like to hear what you got or what others are using as I'm looking for a good monitor for my 5D.
Thanks.
PHIL YUNKER
Yunker Video Production Services
http://www.philyunker.com
http://www.linkedin.com/in/philyunker
Errol Lazare
on Oct 18, 2010 at 8:59:07 pm
I will checkout this monitor as well. I have heard though that the 5d doesn't output hd 1920x1080 out from the hdmi port. Is this true?
How is the Flanders monitor in bright sunshine? Any ideas about a good outdoor portable hd monitor?
Jason Jenkins
on Oct 19, 2010 at 10:10:45 pm
I got the SmallHD DP6 monitor recently. I really like it.
Jason Jenkins
Flowmotion Media
Video production... with style!
Mike Jackson
on Oct 20, 2010 at 8:48:26 am
I use the 7" TV Logic with the DVI input and it looks the best I have seen of all the monitors we tested.Had a friend who just bought 2 Marshalls and returned them when we put them alongside the TV Logic.He then bought 2 TV Logics.This monitor seems to be the best for focus pulling the 5D even at the 480 res .Curios to see if the Small HD DP6 stacks up against the TV logic as I think its smaller size is more practical for some situations especially with its custom zoom for 5D and retaining the 1080 or 720 size.
Mike Jackson
Charlie Herranz
on Nov 1, 2010 at 11:45:13 pm
Hi Mike,
I bought the 7" TV Logic and I'd like to use it with my 7D throught the DVI conector. I've tried with couple of HDMI-DVI adaptors but with not cluk... still not picture on the screen. Could you please, advise me in the adaptors that you use to conect with your 5D?
Charlie
Mike Jackson
on Nov 2, 2010 at 4:56:38 am
Hi Charlie.It should be fine.I have a mini HDMI from camera to HDMI with DVI connector to go into monitor DVI port.Select DVI on front panel and hit Live View on 5D and presto you have pics.Hit info button on 5D twice and it resizes the image and hides the info.I have not used the TV Logic with a 7D so I cant be sure of your problem but it works fine with 5D MK2.DP6 small HD is a great monitor as well.Nice to have both.
MJ
Charlie Herranz
on Nov 3, 2010 at 12:32:15 am
Hi Mike,
Thanks a lot for your help. I actually bought a new HDMI to DVI-I adaptor and it does work now (although there is no WFM or Vectorscope on the DVI input). The adaptor that I had before it was jus DVI (qithout the I)... The DP6 looks great, and I'd love to have a backup, but have enough toys already and not budget for it.
Thanks for the advise!
Bob Pierce
on Nov 3, 2010 at 12:44:12 am
Interesting. Is the image you're getting HD?
Charlie Herranz
on Nov 3, 2010 at 1:00:05 am
The monitor says the video signal is 1920x1080.. 60i (Although the 7D is on PAL mode 50fps) the picture has got a very good quality (I would say it's HD) but it doesn't cover the whole screen sidewise at any point -(even after pressing the info button)... maybe, because it's showing the safety black bars on top and botton of the 16:9 video mode, I suppose...??
Bob Pierce
on Nov 3, 2010 at 1:16:36 am
Thank you Charlie for posting back, that's good to know. I may try some different adapters and see if I have better luck.
Bob
John Fishback
on Oct 24, 2010 at 10:58:40 pm
SmallHD has a very interesting video and text explanation of how to improve monitoring with the DP6. It's worth checking out.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
Bob Pierce
on Nov 2, 2010 at 1:17:58 pm
I have a 7D and the TV Logic, and tried using it with the DVI adapter. I get an image but it's very crappy low res. Maybe there's a menu setting in there that's wrong but I don't think so. I'm intrigued that others are having success with this monitor with Canons. Any suggestions would be appreciated.
Bob Pierce
Richard Cooper
on Oct 26, 2010 at 8:11:51 pm
Thank you all for the great input. It is most appreciated. As of now I have temporarily put on hold ordering the field monitor as we just added a second edit suite to the studio. We are going into our heavy post production season and my needs were greater for this than a field monitor. But I will be making the decision soon and placing my order and will let you all know what I end up with and give some feedback when it arrives.
Thanks again!
Richard Cooper
Anchorage, Alaska
Dave Smith
on Feb 25, 2011 at 2:30:43 am
See my post in another thread re the Flanders monitor. I highly recommend it. http://forums.creativecow.net/thread/54/855612#859797
Dan Swiney
on Mar 14, 2012 at 11:29:32 pm
I read somewhere that the TVLogic and DP6 share the same LCD, it was on the internet so it must be true...
The ability to convert HDMI to SDI makes me lean toward the TV Logic. I compared the Swit S-1071F (aka JVC DT-X71F ), SmallHD DP6, IkanVX7e, TVLogic VFM-056WP, Atomos Samurai for my needs over here: http://www.digitalbuilt.com/?p=169
