7d video output
COW Forums : DSLR Video
Thomas McDonald
7d video output
on Oct 15, 2010 at 5:44:56 pm
Getting ready to do a large 2 camera shoot with 7D canon DLSR and I was curious if you can record to an AJA-Ki-Pro or is the HDMI output only sending an 480 signal to the monitor? I'm trying to solve the timecode and audio issues with shooting with this camera.
Ed Cilley
Re: 7d video output
on Oct 15, 2010 at 8:09:39 pm
I haven't done this, but found the following
He was able to view 1080p on a monitor with the 7D - while recording.
Not sure how that works with audio and the Ki-Pro. I guess you would have to tell the Ki-Pro audio is coming via XLR.
Avid and FCP Preditor
Anything worth doing at all, is worth doing well.
- Philip Dormer Stanhope, Earl of Chesterfield
Shane Ross
Re: 7d video output
on Oct 15, 2010 at 9:50:08 pm
Won't work...I tried. Here's what happens.
- With HDMI connected, the LCD display goes away. So you can't see what you are shooting. The signal is going to the KiPro.
- If you monitor THRU the KiPro, you will note that what you see is the LCD display...with everything you see with an LCD. The grey bars on top and bottom, the display information...everything. Turn off the display info, and you still have those black bars on the top and bottom.
- If you press RECORD on the Canon DSLRs (don't see why you would if you used the KiPro), then the signal coming out of HDMI switches to an SD signal.
But the biggest issue is that you don't get a clean signal. You get the LCD display.
Theo Dubeux
Re: 7d video output
on Oct 16, 2010 at 2:47:40 pm
You can TRY to monitor with the output signals, but there's no way to have an HD signal to record. More info here:
© 2018 All Rights Reserved
