5D and FCP 6.0.6, What to expect....
COW Forums : DSLR Video
Jared Cicon
on Oct 7, 2010 at 5:02:50 pm
Hey Guys,
I am cutting my teeth on the 5D. Just shot a commercial spot and want to make sure I do everything right. I have a few questions I hope someone out there can help me with.
1. Is it time for me to upgrade to the newest FCP version, or can I get away with 6.0.6?
2. The files are .MOV natively, is there a necessary or preferred compression conversion (using Compressor) before bringing them into FCP?
3. To ProRes or NOT to ProRes. Can I get some light shed on this issue, and I beg your indulgence here....I would love some rookie-speak, just to make sure I understand it correctly.
4. What should my import settings be for the timeline/project? I shot it at 30FPS. 1990x1080.
5. Are there any other pitfalls I can avoid by heeding your advice in advance?
As always,....I am here because the humble part of me realizes, many of you are way smarter than I. Thanks in advance for your help.
Jared
Phil Yunker
Re: 5D and FCP 6.0.6, What to expect....
on Oct 7, 2010 at 8:13:54 pm
Hi Jared,
here are some answers to your questions:
-----No, not really. I'm using FCP 6.0.6 and have successfully edited multiple projects with footage from the Canon 5d and 7D works fine. Unless you want to spend the $$ on the latest version of FCP, then go ahead.
-----the files may be .mov however, they are h.264 files, highly compressed and will "bog" down or slow down your system. I transcode all the footage to pro res. There are many ways to transcode the h.264 files to pro res (or whatever you may want to work in or with, i.e if your primary camera was shooting XDCAM then you may want to convert to XDCAM, again this is an example, the easiest way is to use log and transfer in FCP, you have to get the Canon plug in for it, i think this link will take you there
http://www.usa.canon.com/dlc/controller?act=GetArticleAct&articleID=3249
another way is to follow these instructions from Philip Bloom
http://philipbloom.net/2009/10/04/canon-workflow-part-1-importing-and-conve...
---i think you mean you shot at 1920 x 1080-?
best way to set up your sequence in FCP is to create a new sequence, then drop a clip you want into that sequence, FCP will ask you if you want the sequence settings to match the clip settings, if you do, click yes
pitfalls, ???? not sure. the hardest thing for me right now is figuring out the best way to record audio and
how much color or information latitude there is with the original h264 files being converted to another format.
Good luck.
PHIL
PHIL YUNKER
Yunker Video Production Services
http://www.philyunker.com
http://www.linkedin.com/in/philyunker
Noah Kadner
on Oct 7, 2010 at 10:50:38 pm
I'd highly recommend getting Magic Bullet Grinder- here's why:
http://dslrhd.com/2010/06/canon-t2i-and-magic-bullet-grinder-perfect/
Noah
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Canon 5D Mark II and 7D.
Jared Cicon
on Oct 8, 2010 at 4:11:47 am
I'm on it Noah. Thanks brother.
Michael Sacci
on Oct 9, 2010 at 5:54:23 am
Some mis-information in that article.
"... transfer them wrapped up as a group for later transfer in a special way."
There is no special wrapping of the card you just have to retain the card folder and file structure when copying the cards. (Just like you do with P2 cards)
Also you want to use a text editor like BBLite or TextWrangler and not TextEdit or a word processor to do the modification of the plugin plist file.
If you use proxy then Grinder is a no brainer, but I like the TOD TC that Log and Transfer adds to the clips in FCP.
Jared Cicon
on Oct 8, 2010 at 4:10:45 am
Hey Phil,
As usual, I feel like I have stolen something like a thief in the night. So much value in being a member of Creative Cow. Such a wealth of information. I am not sure what I am happier about, My 5 and 7D and how they have simplified the film making process.... or the wonderful help I receive from knowledgeable chaps like yourself. It's a comfort to know gentlemen like yourself are out there and so generous and willing to share your experience.
Thank you.
Jared
Richard van den Boogaard
on Oct 8, 2010 at 10:43:48 pm
Hi Jared,
Depending on what output your client needs, you can indeed go for fullHD (1080p), but 720p (1280x720) often suffices. That gives you the benefit of having some leeway (30%) of digitally reframing your shots if you were not all that accurate upon shooting.
I have no experience with FCP, as I am on Adobe CS5 which is super with respect to DSLR support. No need for transcoding, even when applying extensive filters or color grading.
Good luck.
Freelance cameraman • Editor • YouTube specialist
Michael Sacci
on Oct 9, 2010 at 5:47:36 am
I would test out shooting 720p on these cameras, For many the down conversion to 720p elevates some of the problems of shoot with these camera. Personally I would still with 1080p.
on Oct 11, 2010 at 8:55:07 am
@Michael: I don't see how scaling down your footage in the edit (my 67%-rule) makes any difference in terms of the occassional moire or rolling shutter the Canons have. If it's there, scaling down will not make it worse, right? Only smaller. If so, I have yet to discover an example of that being true.
The benefit of having some ability to reframe (re-applying rule of thirds) a hastily made shot by far outweighs not having that ability at all, I think. For most output destinations 720p is very acceptable; it looks perfect on most any FullHD TV set, as well as Vimeo or YouTube.
Michael Sacci
on Oct 11, 2010 at 1:21:47 pm
I was not talking about downscaling in the edit, I was recommending that the people test shooting 720 in camera, I would never say don't do it but I always recommend that a person test the results. And do more then a quick grap a shoot and look, shoot a lot of different types of shots and look at the results.
Resizing on a timeline is a totally different thing.
on Oct 13, 2010 at 6:44:00 pm
Michael - sorry, I misread your comment.
I think you may be absolutely right. Correct me if I'm wrong, but due to the line skipping technology (how they downsample a full frame sensor image to FullHD), DSLRs do have rolling shutter issues, right? I can imagine this becoming worse if you record at even lower resolution, such as 720p which comes down to higher on-the-fly downsampling...
Freelance cameraman • Glidecam Operator • Editor • YouTube expert
Ronnie Whitting
on Oct 13, 2010 at 12:14:06 am
FCP 7 has the codec of Pro Res LT or QT to use with the H264 conversion with our any problem what so ever. Been using this way for 1 1/2 yrs. NO WORRRIES.
Ron Whitting Executive producer-Owner
A.F. Productions / AFP-HD
Tyler, Texas
Jared Cicon
on Oct 13, 2010 at 12:38:12 am
Hey Ronnie,
Thanks for coming to my aid. At this juncture I only have FCP 6.0.6. I just did my conversions to Pro-Res 422 and they seem to be editing nicely in the sequence. I do however look forward to the day when my pro-res compression choices expand. I think I will wait to purchase any FCP upgrade though since the prevailing wisdom suggests an upgrade from Apple is due here soon.
Jared
