Reformat
COW Forums : DSLR Video
Stephen Smith
Reformat
on Sep 27, 2010 at 8:38:54 pm
I need to reformat a SD card because it went bad. Do you format it just like you would format a hard drive? Do you format it to FAT16?
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Richard van den Boogaard
Re: Reformat
on Sep 27, 2010 at 9:52:15 pm
Advice - do it in-camera. That way you can't do the wrong thing...
cameraman / editor / video marketing consultant
Branded Channels
W: http://www.brandedchannels.com
Ryan Mast
Re: Reformat
on Sep 28, 2010 at 12:14:18 am
If it "went bad," throw it out.
If you want to test it first, I recommend doing a zero-wipe format in Disk Utility, then reformatting it in your camera. If your card is iffy, the zero-wipe will throw an error. And then you throw the card out.
Meteor Tower Films
We make music videos, design video for live theater, and build interesting contraptions.
Michael Sacci
Re: Reformat
on Sep 28, 2010 at 2:14:55 am
The card should always be formatted in the camera. There is a low level format option also.
Stephen Smith
Re: Reformat
on Sep 28, 2010 at 2:59:56 pm
When I put the card into my T2i the camera will not turn on. When I put it into a card reader on my Mac I can see everything on it. So I can't format it in the camera but I can on the computer.
Stephen Smith
Peter Burger
Re: Reformat
on Sep 29, 2010 at 11:58:40 am
FAT16 is not usable for your camera, but you can try to format the card with your computer and then try it again with your camera. If the camera recognizes the card, re-format it with the low-level-format option. If not... well... the card my be damaged and you can throw it away
