Importing 720p 60fps in FCP
COW Forums : DSLR Video
Brandon Morris
on Sep 9, 2010 at 4:09:27 pm
How do I get my 60fps footage slo-mo?
With the HVX it was done by itself.
Brandon Morris
http://www.brandonmorris.com
Canon T2i
13" Macbook Pro (Mid 09) 8GB RAM 10.6
Purchase My Stock Footage:
http://www.pond5.com/artist/brandonmorris
http://www.revostock.com/ViewProfile.html?&ID=53988
Michael Sacci
Re: Importing 720p 60fps in FCP
on Sep 9, 2010 at 5:35:21 pm
You can use software like within Compressor or CinemaTools to confirm the timing to 23.976. There is a app by Red Giant, Grinder that can also do it. Doing it with the software does it the same as what the HVX is doing.
But check out this tutorial, Shane is the man and shows you how to do it.
http://library.creativecow.net/ross_shane/slow-motion_cinema-tools/1
NOTE_ always duplicate the 60p before working in CinemaTools
Cuauhtzin Gutierrez
on Sep 9, 2010 at 5:55:37 pm
You have to use a program like Cinema Tools (which comes with Final Cut Studio).
- Right click and open the clip using Cinema Tools
- Bottom right hand part of the screen in Cinema Tools, there's a button that says "Conform." Click it and choose 24fps or 30fps and then you're done.
The clips automatically change after you click the conform button, even in final cut.
John Fishback
on Sep 9, 2010 at 10:03:32 pm
But as Michael pointed out, first, make a copy of your media. Cinema Tools changes the file it works on.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
