Canon T2i Playback
COW Forums : DSLR Video
Gerry Condez
Canon T2i Playback
on May 24, 2010 at 5:46:06 pm
Just want to know the playback through HDMI. Is the playback continuos or it play each separate clips each time? Just got a Letus but video are very dark even with 50mm f1.8 lens. Thanks
Jonathan Ziegler
Re: Canon T2i Playback
on May 24, 2010 at 7:59:28 pm
You play each clip one at a time - click the "play" button, go to the clip you want, then hit Set, choose your play option(s), then hit set again to select play or whatever.
Jonathan Ziegler
http://www.electrictiger.com/
520-360-8293
Gerry Condez
on May 24, 2010 at 9:51:56 pm
Hi Jonathan, Please clarify the procedure, I dont have that camera yet. Once you hit SET, and choose play option, are there options to play back the entire video from start to end? Or, just the clip you selected, or both. Thanks again.
Jonathan Ziegler
on May 24, 2010 at 11:40:40 pm
Again, just the clip you've selected. As far as I know, there's no way to play back multiple clips continuously. This is all in the T2i manual - download here: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=1... - if you don't have the camera yet, the info won't do you any good. :(
Jonathan Ziegler
520-360-8293
