Putting a 60mm half ball head into a 65mm bowl - will that work?
COW Forums : DSLR Video
Steve Crow
on Feb 5, 2017 at 2:41:19 am
OK, another strange question...but I suck at mechanical things so bare with me on this....I have an older flat head tripod and then I have a tripod head that has a 60mm half ball at the bottom. How to get those two to fit together?
So I found this gizmo on Ebay from a Chinese company that I thought would do the trick which works kind of like a high hat:
http://www.ebay.com/itm/152141010354?ul_noapp=true
problem is that they list the compatible bowl sizes as 65mm (not 60mm) at the small end.
So I wrote to them asking if it would work and they say no it won't but didn't explain why not. So that's my question for you - what would be the downside of putting a 60mm half bowl tripod head into bowl designed for a 65mm? Does it mean the sides of the half bowl of my 60mm half ball wouldn't touch the sides of the larger bowl - and that would be bad????? I think the hole at the bottom of the bowl where the shaft goes through are pretty much always a standard size.
Steve Crow
