I need a flexible right-angle mini-HDMI cable for 5D III on a Ronin M
COW Forums : DSLR Video
Lyle Aspinall
on Jun 18, 2016 at 5:58:13 am
I'm using a Canon 5D III on a DJI Ronin M gimbal, and there's very little room between the camera's HDMI port and the Ronin M's arm. Obviously that's a problem since I can't have the cable bumping into the arm every time the gimbal tilts. I can wedge a regular cable in there and make it work, but only if I pull pressure back on it; needless to say that's not a great idea if I want my camera to last long.
And since it's on a gimbal, I'd like the cable to be as flexible as humanly possible. And short. Yes, I'd like to be short, please.
So I guess I need a cable that has these four features:
1. HDMI to mini-HDMI
2. Right-angle on the mini-HDMI end
3. Very flexible
4. Short -- No more than two feet
5. Oh, and a bonus: I live in Canada, so it has to be able to ship here.
Does anyone have any beads on a source for such a novelty?
Patrick Tumilty
Re: I need a flexible right-angle mini-HDMI cable for 5D III on a Ronin M
on Jun 18, 2016 at 11:48:19 am
Using the same setup as you and this cable has worked fine for us so far:
http://www.bhphotovideo.com/c/product/1062799-REG/hyperthin_sahtu08black_hy...
When our camera is stabilised, there is still a decent gap between the mini-HDMI cable (see above) and the Ronin-M gimbal
I guess you could try some kind of adaptor (but that would lengthen your overall cable):
https://www.amazon.com/Pearstone-Right-Angle-Female-Adapter/dp/B00HCQFUS2
Or something like this could work:
https://www.amazon.co.uk/Sourcingmap-Right-Angle-Adapter-Extension/dp/B00H4...
André Mascarenhas
on Jun 24, 2016 at 4:30:17 pm
Check this out:
http://www.bhphotovideo.com/c/product/1119722-REG/freefly_910_00088_right_a...
Made for Movis, ready for your Ronin :)
