Audio monitoring in Canon 5D Mark II
COW Forums : DSLR Video
Davide Marchesi
on Nov 14, 2014 at 4:24:05 pm
Hello everyone,
I've been researching on the topic of audio monitoring in the Canon 5D Mark II and I thought that the most inexpensive solution would be to get a 3.5mm minijack female to a RCA female stereo cable in order to use the RCA cable provided with the 5D and connect headphones to it to monitor the sound.
Something like this;
However, I didn't know that once the AV minijack is plugged in the 5D the camera display gets disabled because the camera "thinks" that I am connected an external monitor, which I don't have.
A black camera display turns the 5D in a pretty useless thing for video... Moreover, I can't even hear anything from my headphones..
Is there a way to enable the camera display even with the AV minijack connected to the camera?
Thanks everyone!
Al Bergstein
Re: Audio monitoring in Canon 5D Mark II
on Nov 15, 2014 at 4:20:47 pm
I don't think that model will allow you to do (inexpensively) what you want. But check this post out it might answer your question...
Have you looked into using Magic Lantern? It might enable audio monitoring in some fashion on that model
Barring that, perhaps looking at getting the Tascam DR60 under camera recorder might be the next cheapest alternative? They are now under $200 for the slightly older model, and also record on the fly at two different levels. That would allow you to monitor and record three different tracks. I've been pretty happy with mine. There is even a newer model with four XLR inputs!
© 2018 All Rights Reserved
