GH4 variable Frame Rate 96fps
COW Forums : DSLR Video
Lothar Wieland
on Jun 28, 2014 at 6:20:33 am
If I record with the GH4 in variable frame rate @96fps Premeiere Pro or AE shows only 24fps….I'm not sure if I handle the gh4 setting right or is it an issue with handling variable framerates in editing systems. Does anyone has experience with it?
Brian Mulligan
Re: GH4 variable Frame Rate 96fps
on Jun 30, 2014 at 5:35:30 pm
The QT is flagged as 24 and therefore plays in slomo by default. You can go in to PP or AE and interpret the footage on the clip to be 96fps and then it will play in real time.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Lothar Wieland
on Jun 30, 2014 at 6:26:58 pm
Thanks!!!
