Canon 600D frame rate settings
COW Forums : DSLR Video
Isaac Anderson
on Jun 4, 2014 at 11:19:39 am
Can I change the frame rate of a canon 600D to about 10?
I need it for a project, that I could do with pictures, but video at a low frame rate would be the best. If I need to use Magic lantern or similar, that's fine.
I
Email: starstreamvideo@gmail.com
Paul Stancel
Re: Canon 600D frame rate settings
on Jun 14, 2014 at 9:29:12 am
Yes, i believe you will need magic lantern for that, i think that the lowest framerate on the 600d is 24 fps, in magic lantern you can go down to like 1 fps, there is a great tutorial on youtube on how to install magic lantern
