DSLR video file GLITCH: pixelated motion on source. NEED repair program/workflow advice
COW Forums : DSLR Video
Anthony Ferrara
on May 27, 2014 at 11:24:45 am
I am editing a large project of video footage collected for multiple Canon DSLR cameras. I've noticed one of the cameras has a consistently glitch that appears for an average of 6-12 frames at least once per video file. To the best of my knowledge the glitch is not the result of the memory cards or camera (SanDisk Extreme Pro SD on a 6D), but I suspect it may have to do with disrupted offloading or an improperly ejected hard drive that was reported by our DIT.
More about the glitch: It appears as either pixelated segments or repeated frames that seem to occur with rolling shutter discontinuity that is common with panning or general camera motion. I've uploaded a short clip with the glitch here (occurs at 2 second mark): https://vimeo.com/96575338
Has any one else experienced this glitch on Canon DSLRs or with interrupted video offloads? Is there fix or program I can apply to the source file? Could anyone respond with general info about the glitch -- a more specific name or the root cause to prevent it from happening again?
Thank you,
Anthony Ferrara
DP - CameraOP - Editor
Bokeh Monster Video
http://vimeo.com/bokehmonster
Luar Dov
Re: DSLR video file GLITCH: pixelated motion on source. NEED repair program/workflow advice
on Jun 16, 2016 at 10:43:32 am
Have the exact same problem. The source of the problem seems to be the card reader.
Have you found a solution?
