Difference between 'normal' 600D footage and that same footage exported as a apple prores 442 format
COW Forums : DSLR Video
jordi mol
on Jan 23, 2014 at 9:53:02 pm
Hi all,
its my first time here and i am new to edditing. I have a question which is, what is the best way to color grade you footage and what is the difference? For example i have one piece of footage, one normal .mov straight out of my canon 600d, the second is the same clip only first i exported it to apple prores 442 (hq).
Then i imported both in a sequence in premiere pro cs6. First off the 'normal' one, second the prores on. When i apply the same lut to both, the differences are realy big. The first 8 seconds is the normal footage, the second 8 seconds are the prores footage. You can see a big difference in both clips, color wise. Both with the same lut on them.
Any help/explenations for me?
Thanks in advance!
link to the video:
http://reels.creativecow.net/film/difference-between-normal-600d-footage-an...
Jordi
Mike Smith
Re: Difference between 'normal' 600D footage and that same footage exported as a apple prores 442 format
on Jan 24, 2014 at 3:50:04 pm
Yes they are different. You don't say what your original footage is, but I'm guessing it's not a quicktime file, as your ProRes will (very likely) be. QT color management can produce issues.
These might give you a bit more.
https://developer.apple.com/library/mac/technotes/tn2227/_index.html
There's more at http://lesterbanks.com/2012/08/circumvent-qts-color-management-by-creating-...
http://www.liftgammagain.com/forum/index.php?threads/crushed-blacks-in-qt-e...
