60D imported footage flicker/gray frames
COW Forums : DSLR Video
Dan Callahan
on Jan 7, 2014 at 9:05:26 pm
Hello all, I've been shooting all of my recent projects on the 60D and have found that when I import the shots into Adobe Premiere Pro, every few seconds there will be a gray/dropped frame when I play back the source footage in the monitor. I'm not sure if this is a problem exclusive to adobe, but it makes me worry about using certain parts of the footage due to the occasional gray frame. I have exported projects and the flicker does not seem to occur when I post a project to the web. I am pretty careful about not using portions with gray frames tho, so I can't be sure.
Just curious if this is a common problem that is universal for DSLRs or if it is only exclusive to premiere.
