color banding when shooting in daylight - MK II
COW Forums : DSLR Video
lauren phillips
on Nov 4, 2013 at 8:03:26 pm
Hello!
I am new to DSLR and color correction. I recently shot a film in Hungary outside in daylight. All of my footage looks great except for a handful of shots shots where only the red roofs seem to be doing this weird blue banding? Could anyone tell me why this is happening and what if anything I could do to fix it? Or hide it a bit?
Thanks so much!
Chris Wright
Re: color banding when shooting in daylight - MK II
on Nov 5, 2013 at 12:02:30 am
there might be a plugin out there that removes strobing and moire in one go. I don't know. Hopefully someone else can chime in.
In the past, I made a pretty good strobe and moire reducer AE project.
It does it in 4 parts. The only thing is, there's no auto mask. How you track the bad part is up to you.
mask out the bad part
median effect for chroma blur
shutter blur the strobing
vibrance the lost color
AE 5.5 nomoire&strobe
6749_6415nomoirecs5.5.aep.zip
lauren phillips
on Nov 13, 2013 at 10:13:53 pm
Is there anyway to do it with Final Cut Pro? I unfortunately don't have After Effects. Or is it something that can only be fixed with AE?
Do you know what may have cause it to begin with?
Chris Wright
on Nov 14, 2013 at 12:55:25 am
this plugin for fcp doesn't work with red bricks very well
http://philipbloom.net/2011/02/17/moire/
the best way is to download a demo of After Effects or try to get FCP to use a tracked mask, median filter set as a color transfer. It blurs only the color channel.
you can also try some sort of channel mixer, channel blur and use an optical shutter blur on the strobing.
and finally some sort of saturation boost to recover the desaturated chroma blur.
