Overexposure problems @ 1/50 - how to correct?
COW Forums : DSLR Video
Elin grome
on Jul 16, 2013 at 4:17:25 pm
Hi guys,
As recommended I shoot dslr vid @ 1/50sec shutter @25fps - but frequently shoot outside in bright sun.
At those shutter speeds this often means an overexposed image - what is the best way to correct for that?
I can obviously speed up the shutter - but i'll often need to go way up to 1/500 or beyond to balance the image - and that can lead to choppy/video like motion...
help!
Elin
It's all the those pesky details :p
Fernando Mol
Re: Overexposure problems @ 1/50 - how to correct?
on Jul 16, 2013 at 4:54:22 pm
You can get a good set of ND filters.
http://en.wikipedia.org/wiki/Neutral_density_filter
I hope this helps
http://www.fernandomol.com
Jason Jenkins
on Jul 16, 2013 at 5:38:31 pm
Yes, I have a variable ND filter that is really a must-have for shooting outdoors. Make sure your ISO is turned down all the way. You can also close down the aperture to get the correct exposure, but for the most flexibility, a variable ND is the way to go!
Jason Jenkins
Flowmotion Media
Video production... with style!
Check out my Mormon.org profile.
Steve Crow
on Jul 16, 2013 at 6:24:56 pm
Yes like everyone else has said, cutting down the light with a Vari ND filter is a great way to go and is what I also do. Don't use the shutter speed for this unless you are trying for a very specific look, on a static shot (no movement) it might matter less but I simply consider my shutter speed to be permanently welded to 1/50 except for when I am filming 60fps slow motion stuff.
Of course you can also adjust the aperture but if you are going for the shallow depth of field look then you are limited there too.
Steve Crow
Crow Digital Media
http://www.CrowDigitalMedia.com
Elin grome
on Jul 18, 2013 at 2:23:23 pm
Perfect! Thanks guys. Variable ND filter on order.
Elin grome
on Jul 18, 2013 at 2:26:23 pm
actually - one more thing Re. variable ND's; the cost...
like most equipment prices vary enormously $10-$150...
can anyone give me guidance on how much I should look to spend?
Fernando Mol
on Jul 18, 2013 at 2:38:35 pm
The best one you can afford. Avoid putting a cheap piece of glass in front of your fine lens.
charles meadows
on Jul 19, 2013 at 7:25:52 pm
Use a variable ND filter on your lens.
"There's no point in filming if you don't have fun"
Charles Meadows
Creative Director
Incubate Productions South Africa
http://www.incubatevideo.co.za
