Mixing Canon 5D 1920x1080p with Z1 1440x1080i footage on same timeline - is it possible?
COW Forums : DSLR Video
Harjite Dosanjh
on Feb 10, 2013 at 12:25:29 pm
Hi Guys,
Need some advice with the following issue.
I have footage captured form a Sony Z1 and from a Canon 5D MKII. My Sony footage is 1440x1080i and my Canon footage is 1920x1080p.
Im using Premiere Pro CS5.5 for editing.
When I export the footage and burn with Encore I am have field issues. I have tried many things to remove this issue but nothing is working? I have tried to change the 1080p footage to upper field but no luck.
Has anyone ever work with these different element and managed to burn a blu ray without any field issues?? If so pleas could you share how you did so?
Many thanks in advance!
Harjit Dosanjh
H
Harjite Dosanjh
Re: Mixing Canon 5D 1920x1080p with Z1 1440x1080i footage on same timeline - is it possible?
on Feb 11, 2013 at 2:12:23 pm
Hey Bob,
Thanks for your response mate. Ill give it a go and see how I get on!
H
Harjite Dosanjh
on Feb 11, 2013 at 2:19:34 pm
Quick question, in PP which sequence setting would you use? DSLR 1080p25 or HDV 1080i25 (50i)?
Many thanks!
Harjit
Harjite Dosanjh
on Feb 12, 2013 at 11:48:47 pm
Thanks again Bob! Appreciate the advice!
Minu T A
on Aug 26, 2014 at 8:55:43 pm
the reply post seems to be removed..i too have the same issue matching 5D with Z1.which sequence setting would you use? DSLR 1080p25 or HDV 1080i25 (50i)? i would also like to know if the same is possible in FCP
