D800 Color Bars
COW Forums : DSLR Video
Gregg Schieve
D800 Color Bars
on Jan 25, 2013 at 3:18:41 pm
Is there a way to import color bars into a Nikon D800? I'd like to calibrate a video monitor with color bars from the camera. When I write a color bar image to the memory card, the camera tells me that it can't read the file.
Sareesh Sudhakaran
Re: D800 Color Bars
on Jan 25, 2013 at 3:43:07 pm
Not as far as I know. Shoot the color bar under ideal conditions and you can use it to set white balance. But then again, that's what color and grey cards are for.
http://www.wolfcrow.com - Workflow information and support for filmmakers, photographers, audiographers and videographers.
Gregg Schieve
Re: D800 Color Bars
on Jan 25, 2013 at 5:10:35 pm
OK. Well, using color bars to calibrate a monitor has nothing to do with white balance. Thanks anyway.
Chris Wright
Re: D800 Color Bars
on Jan 26, 2013 at 3:25:06 am
Color bars wouldn't work even if you recorded right off a monitor. Why? Luts only exist on the canons, example, cinestyle. You only have the flat neutral look on yours. The most the color bars would help with would be matching other similar cameras. There's no standard or color management going into your computer. You are probably looking for a standard model that can be created with this software for profiles.
http://spyder.datacolor.com/portfolio-view/spydercheckr/
http://spyder.datacolor.com/portfolio-view/spydercube/
