sequence clips list by seq. time - error message
COW Forums : Square Box CatDV
Carsten Orlt
on Jan 26, 2010 at 6:06:50 am
I'm just trying the demo version and are very close to get a licence BUT one big problem:
What I will need quite often is to export a FCP seq via XML and create a text list of the used clips by sequence timecode.
Now I can import the XML into CatDV without problems but then I get the following error when I try to display clips by seq. TC:
"Failed to select clip (java.lang.NullLPointerException)"
Anybody knows what that means?
Cheers
Carsten
Carsten Orlt
Addition: sequence clips list by seq. time - error message
on Jan 26, 2010 at 6:48:53 am
Addition:
I now figured out that it can only be a bug in CatDV.
When I select to list 'source clips' from the seq. all clips are fine.
When I look at 'All clips' the first 2 clips from the seq. are not showing correctly (they can't correctly link to the media)
I checked FCP seq and XML file and they look fine (no super expert so I might have overlooked something).
Anybody else having problem with this functionality?
Cheers
Carsten
Carsten
Rolf Howarth
Re: sequence clips list by seq. time - error message
on Jan 26, 2010 at 9:13:29 am
Yes, that sounds like a bug. Can you mail the XML file you are using to support@squarebox.co.uk so we can investigate please?
