Generate proxy utilize Matrox Compress HD chip?
COW Forums : Square Box CatDV
Jason Brown
on Mar 9, 2011 at 5:50:01 pm
Can generate proxy use a CompressHD card from Matrox?
bryson jones
Re: Generate proxy utilize Matrox Compress HD chip?
on Mar 9, 2011 at 6:12:32 pm
I've not done it, but since CatDV uses the QT engine and the Matrox works with the QT engine, I'm sure you could just select it as a codec option when you set up your previews.
This is how folks do it with the elgato accelerators.
Also, for the record, you can also hand off a proxy generation job to Episode or any other heavy duty compression engine if you need "big boy pants".
bryson
bryson "at" hidefcowboy.com
hidefcowboy.com
Jason Brown
on Mar 9, 2011 at 9:48:08 pm
I just love the speed...I'm a huge advocate for the CompressHD...not used the Elgato though.
I'll look for you at NAB! :)
-Jason
