Change clip status subject to condition
COW Forums : Square Box CatDV
yannick guillerm
on Feb 16, 2011 at 4:57:12 pm
Created a Server Query Watch Action based on the status change of a clip. Running a command. What I want to do next is to set the clip status to "DONE" (in Post-"Processing", ""Set clip details", "Status="), BUT only if my command succeeded. I can get the return code of the command.
How would I do that?
Thanks.
Yannick
Yannick Guillerm
System Engineer
Atempo Inc
yannick.guillerm@atempo.com
650-812-3056
Rolf Howarth
Re: Change clip status subject to condition
on Mar 3, 2011 at 9:16:05 am
Sorry to come to this late but if you execute your command in the "command 2" part of your worker script and check the 'parse output' option then you can set the clip status (or any other field) programmatically based on what your command returns.
