CatDV/Premiere Pro extension question
COW Forums : Square Box CatDV
Brad Baker
on Feb 5, 2018 at 4:40:02 pm
How do you choose which CatDV details panel shows up in the Premiere Pro extension?
John Vaudin
Re: CatDV/Premiere Pro extension question
on Feb 5, 2018 at 6:23:43 pm
Normally the Premiere Panel will show the same panels as the web client would. These are configured through the Panels section of the web admin UI. If you've got a reasonably new version of CatDV Server then you can specify a panel set specifically for the Premiere Panel by choosing Premiere Panel from the 'client' section of the visibility rules.
Brad Baker
on Feb 7, 2018 at 5:57:24 pm
Great, thanks John. I was able to set it up in the Server visibility rules.
