Adobe Premiere Panel Issue
COW Forums : Square Box CatDV
Alex Schmidt
on Oct 21, 2016 at 3:10:38 pm
Hello everyone!
I am currently having an issue with the Adobe Premiere Panel; it is not allowing me to connect to my CatDV Server. Here is the process I followed:
1. I installed the Premiere Panel along with the extension feature (from Adobe Creative Cloud).
2. Restarted Computer.
3. Opened up Premiere Pro CC, clicked on "Window">"Extensions">"CatDV"
4. I have one text field that only allows me to type in the "CatDV Server:".
5. I typed in the Server Address (not the default localhost) that the Desktop Client is connected to, and it just sits on "Connecting.."
What am I missing? I noticed that in the video from Squarebox there are three fields that ask for "CatDV Server:", "Username" and "Password", however I only have the one "CatDV Server: field" to enter in the Premiere Panel.
We are on CatDV server 7.1.0.
Any help would be appreciated, thank you!
Alex Schmidt
Re: Adobe Premiere Panel Issue
on Oct 21, 2016 at 3:55:39 pm
Additionally, we have the Adobe Creative Cloud for Teams, not Enterprise if that makes a difference. There was mention of supporting "Adobe Anywhere" which I noticed is only available to Adobe Enterprise memberships.
Dougal Matthews
on Oct 25, 2016 at 10:57:07 am
hi Alex
you need to supply address and port
so if your ip was 192.168.1.2 and your catdv webserver was running o nthe default port 8080
you'd need to use 192.168.1.2:8080
or if you had a hostname of catdvserver
you'd use catdvserver:8080
there's also some good guidance on the panel here which may be useful
http://www.squarebox.com/premiere-plugin/
thank you Dougal
Improvise Adapt and Overcome
Alex Schmidt
on Oct 25, 2016 at 8:35:37 pm
Perfect! It worked, thank you! I had to use a different port # in the end; I was not aware you had to include that.
Thank you!
