Importing DPX Sequences into CatDV
COW Forums : Square Box CatDV
Eli Garrett
on Apr 25, 2016 at 4:32:59 pm
I have about 50 DPX sequences that I want CatDV to track. I can import a image sequence to get Catdv to track the DPX sequence., but I can only do it one by one and it takes a really long time for it to import. Is there any way to bulk import DPX sequences in Catdv? After I have gotten 2 or 3 sequences into Catdv it becomes really slow and almost unusable any recommendations for how to handle DPX in Catdv?
Dougal Matthews
Re: Importing DPX Sequences into CatDV
on Apr 26, 2016 at 12:54:08 pm
hi Eli
as you have discovered the client isn't really built for bulk import we have a companion tool called the worker which is designed for that sort of automation see
http://www.squarebox.com/worker-node-6/
so if you regularly need bulk import I'd suggest using the Worker
thank you Dougal
Improvise Adapt and Overcome
