Database Connection Refused
COW Forums : Square Box CatDV
Andrew Saliga
on Feb 10, 2016 at 12:00:48 am
I recently upgraded the Mac running CatDV Server to OS X 10.9.5 and have been unable to restore my backed up database. I performed a clean install of Cat DV Server, but can't get it to import. I get the following error: 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2).
OS X 10.9.5
CatDV Server 6.9.4
CatDV Pro 11.0.3
MySQL 5.7.11
Andrew Saliga
I/O Specialist/Editor
Steelehouse Productions
http://www.steelehouse.com
John Vaudin
Re: Database Connection Refused
on Feb 10, 2016 at 9:11:29 am
It sounds like MySQL just isn't running? If you go to the MySQL control panel (in System Preferences) does it show MySQL as running?
If it's not that is then I would just contact support by emailing support@squarebox.com.
Andrew Saliga
on Feb 10, 2016 at 6:05:13 pm
Thanks John. Seems like that is the issue. For some reason it won't start. Scouring forums for a solve... trying reboots, reinstalls, and permissions.
Andrew Saliga
John Vaudin
on Feb 10, 2016 at 7:40:43 pm
Did you install the right MySQL version for your Mac OS version? Apple have changed the way daemons (background services like MySQL) get launched and there are definitely issues with certain versions of MySQL on certain versions of Mac OS. I'd probably update to the latest Mac OS and the latest MySQL and see if that fixes it.
Andrew Saliga
on Feb 11, 2016 at 7:59:45 pm
Thanks John. You're probably right on that one. I'll give that a shot, but unfortunately it'll be a long process due to some software dependencies that are only licensed for 10.9.5. I'll need to purchase the upgrades along with updated OS and MySQL in order to have a functional system again.
Andrew Saliga
John Vaudin
on Feb 11, 2016 at 8:05:03 pm
There is definitely a MySQL 5.7 install for 10.9, so it should be possible to get it working. You might need to manually set up a LaunchDaemon entry as described here: http://stackoverflow.com/questions/26476391/how-to-auto-load-mysql-on-start..., and its possible the status in the control panel won't be right, but it should be possible to get it to work.
Andrew Saliga
on Feb 11, 2016 at 8:06:01 pm
Excellent. Thanks John. Trying those steps now.
Andrew Saliga
