Change Media Path
COW Forums : Square Box CatDV
Chad Gilmour
Change Media Path
on Jan 12, 2016 at 10:34:15 pm
Maybe a stupid question, but can you change the "Media Path" of files already in CatDV?
I know you can add entries to the "Media Search Paths" which basically has the same result. Just wondering if it's possible or not.
John Vaudin
Re: Change Media Path
on Jan 13, 2016 at 9:32:05 am
Yes. In the Media menu select "Update Media Location" and navigate to the new location of the file. If you've moved many files, you can multi-select clips and it will try to apply the same 'move' to all the files it can. You can also set up a path mapping rule from old to new, but generally better to update the records to point to the right place.
Chad Gilmour
on Jan 13, 2016 at 3:05:27 pm
Perfect! Exactly what I was looking for! Thank you!
