Report for unique content?
COW Forums : Square Box CatDV
Lee Warner
on Dec 15, 2015 at 11:06:08 pm
We use a field named CLIENT for all of our assets that indicates who the media is attached to. Is it possible to create a simple report that shows all the unique names in the client field (but only one view per client)?
Lee
SAMDOG Digital Post
Calgary, Alberta based Post Production Specialist & visual problem solver. Fluent in Avid, Premiere Pro, After Effects, yada, yada, yada.
Available for hire.
Calgary, Alberta YYC · tinyurl.com/6vgfa3f
Rolf Howarth
Re: Report for unique content?
on Dec 15, 2015 at 11:54:20 pm
If you have the CatDV Worker Node you can use the catdv command line tool with the -distinct or -summarise options to display all the values of your CLIENT field, together with the number of assets belonging to each client.
bryson jones
on Dec 16, 2015 at 4:10:05 am
Ah, that's a good one Rolf. Thank you
bryson
bryson "at" northshoreautomation.com
Lee Warner
on Dec 16, 2015 at 10:25:34 pm
Rolf,
Thanks for your help. After looking at http://www.squarebox.com/worker-command-line-interface/# I tried using the command line however it isn't working for me. See screen cap below. Can you point me in the right direction?
Lee
SAMDOG Digital Post
Available for hire.
bryson jones
on Dec 17, 2015 at 2:18:39 am
Sorry man, Rolf will have to help, I'm more Linux, OSX.
But know that you generally have to add the "catdv" app to your shell or call the explicit path. (Not sure how that works on Windows.)
Do not quote me on any of this, others on the NSA team handle the Win side. lol
bryson
Rolf Howarth
on Dec 17, 2015 at 10:52:44 am
That's a path issue. Either edit your PATH environment variable or provide the full path, eg.
C:\Program Files\Square Box\CatDV Worker 6.1\catdv.exe -help
-Rolf
