Prelude XMP to CAT DV
COW Forums : Square Box CatDV
Dan Lewis
on Jul 8, 2015 at 8:42:28 pm
Does anybody know if it is possible to bring your logging information from Adobe Prelude CC 2015 into Cat DV? So far I can only get comments to appear as text in the Technical window of CAT DV.
bryson jones
Re: Prelude XMP to CAT DV
on Jul 10, 2015 at 12:48:30 am
It should work.
Check in your "Other" fields for the METADATA fields. You may find that some of the fields from Prelude are in there, grouped together.
For larger clients we've put in scripting to separate data coming out from Adobe Bridge in the past and this was how that worked.
Let us know.
bryson
bryson "at" northshoreautomation.com
